The starter motor stopped working. I followed the tests in the VP Electrical Manual and identified that the solenoid was at fault. Because I wanted to get some fogging oil in I tried to use a jumper cable directly to the starter from the battery. The starter spun but not fast enough to engage. I presume this is because the connections done by hand were not good enough to get the required current to the starter.
1) Does this make sense?
2) Should I get a replacement soleniod or replace the starter as well as its six years old?
Regards
Chris
Regards
Chris
