evinrude propeller trouble
silverc
we have a 85hp evinrude runs great took it out to pull a wake board while running the boat stopped going forward. we were able to move at a slow speed to dock but when pushed no speed. help
emdsapmgr
Re: evinrude propeller trouble
Perhaps you spun the hub in the prop. Did you try another prop?
Silvertip
The hub is separated from the outer part of the prop by a rubber packing. The bond between the hub and this rubber lets loose and although it may hold power at low speeds, it begins to slip at higher power settings. Place a mark on the hub of the prop. Place a second mark in-line with the first, on the outer part of the prop. Run the boat until the problem occurs. Check the alignment of the two marks. If they are no longer in-line, the prop needs to be repaired or you need to replace it. If the marks are slill in line, something else is wrong.
