  #1
Old February 2nd, 2007, 12:00 PM
ABFishin69 ABFishin69 is offline
Default New Boat advice
Guys,
I love this thing. Alright I am looking at purchasing either a 17' or 18' deep v boat. I am currently looking at The Tracker line - either the Targa 175 WT or 185 WT both come with 90hp Optimax. I have also glanced at the Sylvan, Trition and G3 boats and I am having some trouble deciding. I used to own an 18' fibrerglass that was a project but it was really heavy and I think I want to go to the Aluminum becasue they are lighter and better to tow. Also, you don't need as many ponies to get it to plane. Here are the factors. I am on a budget but I am looking to stay in the 23k range (as a package) but I guess I am not sure which brnad is better - all seem to have similar standard featuers. The boat will be in used in the potomac river for striper, catfsih and smallmouth. It will also be used for a little bay fishing as well which is why i was looking for the Deep V. I also will occasionly get a tan and pull some tubes with it as well. So all of your input would be nice. Thanks!
  #2
Old February 2nd, 2007, 04:39 PM
KCook KCook is offline
Default Re: New Boat advice
Might want to also think about motor brand. I believe Tracker and Triton are both Merc only. G3 is Yamaha only. Dunno about Sylvan. Lotsa aluminum brands out there. Any other dealers in your area?
Kelly Cook
  #3
Old February 4th, 2007, 01:02 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
tracker had some bad raps about warranty, and leaks, a while back. go with the one that has the best service dept.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #4
Old February 4th, 2007, 09:37 PM
Silvertip Silvertip is offline
Sylvan is generic -- they are pre-rigged according to dealer order. In fact you could buy a boat with no engine at one dealer, and go to another for the engine of your choice. They are good boats by the way. Not on the high end of the quality scale but great value for the money.
  #5
Old February 5th, 2007, 11:01 AM
ruf1967 ruf1967 is offline
I used to own a 1990 17ft deep vee walleye boat with a riveted aluminum hull and never had a problem with the rivets "weeping". You might also want to check out starcraftmarine.com
__________________
2006 Sea Ray 185 Sport
4.3L V-6 190 HP
65 hours
  #6
Old February 5th, 2007, 11:51 AM
arthat arthat is offline
I second checking the Starcraft / Fisher Aluminum brands. I have had both the Starcraft for over 30 years and currently a Fisher 12 years and going strong. Both made in same factory by the way. They both are great in the shallow creeks and do well in the bay too.
I hope this helps
Successful Boating
Art
  #7
Old February 5th, 2007, 01:18 PM
Err, I thought Starcraft and Monak are related. As are Fisher and Tracker. But not Fisher and Starcraft ....
Kelly
  #8
Old February 5th, 2007, 03:52 PM
Hi KCook,
Well, if you check the hull #'s on starcrafts and on Fishers, they both start with STR, at least they did in 1995 and a dealer whom I have known and trusted for many years explained they were from the same plant. As we know, there have been many changes in corporate America since then.
Successful Boating,
Art
  #9
Old February 5th, 2007, 04:10 PM
KCook,
You are correct! In calling Tracker Corporate, I learned that Fisher was aquired by Tracker from the Brunswick Corp. about 1996. Fisher is nownaffiliated with Tracker.
Successful Boating,
Art
  #10
Guys,
THanks for all of your advice. I am guessing you guys would suggest going with an all welded hull vs. a riveted one correct? I feel have a welded hull is better...??
Also, are the Merc Optimax's good motors. I have read good and bad reviews and we could probably debate this all day. From what I can tell my previous top choices (Tracker, Triton) are Merc only so I just wanted a dependable motor. I wish I could get one of those new Rude E-tecs on it.
Looks like I am going to have to look into a new Starcraft/Fisher from what you guys are telling me. I will jump on the websites now.
Andrew
  #11
Old February 5th, 2007, 04:24 PM
Ok. I didn't know that happened in '96. Can't keep up around here without a playsheet!
Cheers,
Kelly
  #12
Old February 5th, 2007, 05:09 PM
bassboy1's Avatar
bassboy1 bassboy1 is offline
See my avatar. I would suggest the 1750 Tyee or the 1700 pro sport.
__________________
http://www.shareaproject.com/pages/p...,p,482,00.html
Click above to view my 1542 jon boat project.
  #13
Old February 5th, 2007, 10:03 PM
scoutabout's Avatar
scoutabout scoutabout is offline
Just a quick note to say that there can be huge value in a used boat that's only seen a couple of season's use. There ain't much that depreciates faster than your average family boat.
Happy hunting. Not much I'd rather be doing than boat shopping!
__________________
Not everything that can be counted, counts -- and not everything that counts can be counted.
- Albert Einstein
2004 Scout Dorado 170 Dual Console
Yamaha 90 4-Stroke
  #14
Old February 6th, 2007, 04:45 PM
JasonJ's Avatar
JasonJ JasonJ is offline
Don't know if you can get 'em over there, but you should also consider Hewescraft, Ducksworth, etc. If you look into the Pacific Northwest aluminum boat builders, you will see that they build extremely durable welded hulls design specifically for brutal water conditions. Your other choices are fine, and you'll want to include Crestliner in your search. I myself am partial to Ducksworth, but I also like Crestliner. Smokercraft is another decent one.
I just spent this last weekend crawling all over aluminum boats, the Duckworth and Hewescrafts had excellent attention to detail, although carpet was something that was not on these boats. The Sylvans, Starcrafts, Crestliners, Trackers all seemed to be fairly even as far as fit and finish, so among them I don't think you can really go wrong. Your dealer support is what is goin to determine your positive or negative experience with any boat, so you should include that in your decision.
Also, Scoutabout brings up a good point. I see a decent amount of really nice aluminum boats well equipped for thousands less that are only a few seasons old. We get a lot of people who think they want to fish for the big boys and realize that it takes patience and work, and they give up. Or the wife convinces them that the wakeboard boat is much more usefull than a dumb ol' fishing boat (baffling mindset, I just don't understand ).
Good luck...
__________________
Project Skanky Beast http://70silverline.250free.com/Skankybeast.html
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Advice on a new boat dave_s Boat Topics and Questions (not engine topics) 9 December 2nd, 2004 06:16 PM
Advice for a new or used boat mordecai Boat Topics and Questions (not engine topics) 10 July 30th, 2002 12:15 PM
Need boat advice chiefski Boat Topics and Questions (not engine topics) 6 July 11th, 2002 12:11 PM
Need new boat advice pepper66 Boat Topics and Questions (not engine topics) 5 March 16th, 2002 01:40 PM
NEW BOAT ADVICE Jim Del Boat Topics and Questions (not engine topics) 7 February 26th, 2002 05:17 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
