Dan Boarman
- Nov 4, 2006
- 4
I have a 40 hp Evinrude that has the S.L.O. feature. It kicked it yesterday as I was running. First the "check engine" light came on, along with an alarm. I slowed to an idle and checked the tell tale, a good stream of water was coming out. The engine idled fine. I put the engine in reverse to clear any debris from the intakes. After a few seconds the light and buzzer stopped. However, when I tried to come up on plane again, the engine would speed up and then immediately drop back to a fast idle, the repeat this sequence as long as the throttle was forward. I only had about a mile to go to the dock and "fast idled" the way in. After about an hour I tried the engine again and it worked fine,.
My questions: is there something other than temperature that can cause the SLO feature to kick in? And, if I had shut the engine off, would that have "reset" the SLO switch? This assumes the problem, if overheating had gone away.
The engine is self oiling (not mixed gas) and the oil tank is almost full. Again, everything seemed to work fine after the engine cooled and was restarted.
Many thanks.... Dan
Many thanks.... Dan
