Re: 2000 Model Bass Tracker Outboard
To check for a spun hub, place a mark on the hub and another one on the blade part of the prop directly in line with the first mark. Run the engine until the problem occurs. Now check the marks. If they are still aligned, the prop is not the problem. If they are not in line the prop has a spun hub. The AV plate is the antiventilation plate. It's the flat plate directly above the prop. A short shaft measures 15 inches from the transom bracket to the AV plate. Long shaft is 20 inches. If the motor worked ok before and this is a new problem, I suspect its a prop issue. In other words, the prop can absorb power until it reaches 3500 rpm. At that point the slippage begins because the hub cannot hold the power any longer.
