  #1
Old January 28th, 2007, 05:28 PM
fishjohn fishjohn is offline
Default Kicker Motor
I have a Fisher 14" Avenger with a 25 Hp Mercury 2 cycle engine. I have received conflicting Information regarding the application of a Kicker Mortor. Bass Tracker, the Manuafacture of Fisher, does not reccomend a gasoline kicker, and suggest taht I use a transom mounted Electric Motor instead. The Dealer Suggest that I use a 4 Hp. Mercury 4 Cycle Engine. I am looking for suggestions.
  #2
Old September 6th, 2007, 12:20 AM
UpstNYer UpstNYer is offline
Default Re: Kicker Motor
Hi John,
Based on my experience, you should be fine if your main power unit is smaller and lighter than the maximum allowed for the hull and if your kicker is fairly light. The main issue, I believe, is transom strength. As a secondary issue, you don't want the boat to get so heavy at the stern that the stern rides too low when someone sits back there.
If you could find an old 5 horse 2-stroke of 35 to 45 lbs, that would be good. Don't know what the 4-strokes weigh but have heard they're heavier. Even if your main power is the max for your hull, you may be OK.
My boat's a little bigger than yours; it's an '02 Avenger Pro 16 SC with an '04 90 Merc 2 stroke for main power...max for the hull. Next to it sits a long shaft '81 Merc 9.8 electric start. The kicker's just clamped to the 'higher' part of the transom to the left of the 90. Chose the position carefully to make sure that the 9.8's as close to the centerline as possible without any possibility of hitting or being hit by the 90.
Before running the kicker with the 90 (used to have a 40), I contacted Fisher. They took some time responding, but finally said there should be no difficulty. So far, that's been true. To determine for myself beforehand whether the extra weight would make the stern ride too low, I simulated the weight of the kicker with sandbags and then sat in the stern. It rode low, but not too bad. Glad the 2-stroke Merc 90 is relatively light.
In my opinion, the 9.8 makes the boat a fisherman's dream. Don't have to keep crankin' up the big motor to reposition 30 ft., can troll at fractions of a mile per hour for hours on end, can run through weeds without fouling the big motor, docking is much easier, can explore shallow areas without worrying about expensive damage to the 90, got backup for getting home, plus it saves on gas.
For trolling, I just leave the big motor down and use its lower end as a rudder controlled from the wheel while the kicker stays centered and provides the power. Into the wind at very slow speeds, this doesn't work real well; but the rest of the time it ranges from OK to great.
I wasted a lot of time looking at fancy mountings and kicker steering gimmicks. Finally, one day I just grabbed the 9.8 and hung it on the transom. Best thing I ever did to that boat. Hanging the 90 back there was the second best.
Bob
  #3
Old September 6th, 2007, 01:05 PM
wpmarks46@hotmail.com wpmarks46@hotmail.com is offline
  #4
Old September 20th, 2007, 02:47 PM
Captain Caveman Captain Caveman is offline
A 14 footer with a 25 horse, eh? Just spend a few hundred on a bow-mounted trolling motor. I had a 25hp on my 16' Fisher and now use a 35hp. They both dial down real well to a slow troll. In my opinion you don't need a kicker. Those are for the folks with bigger motors that can't run at an optimal slow speed for fishing.
Bow mounted motors are nice, especially if you get the kind that has the built-in auto pilot. I wish mine had that.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Kicker motor chad perry Boat Restoration and Building 2 April 3rd, 2006 05:20 PM
New kicker motor WRCuddy22 Yamaha & Suzuki Outboards 11 December 2nd, 2004 12:11 AM
What HP should a kicker motor be? rboat99 Non-Repair Outboard Discussions 7 July 15th, 2004 05:56 AM
Kicker Motor ? jofish Non-Repair Outboard Discussions 4 March 24th, 2004 06:01 AM
Kicker Motor AnyTime Non-Repair Outboard Discussions 1 February 14th, 2001 07:39 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
