19' BR. Winshield is sealed up OK but the side windows (those ones that angle down to hull, about 3-4' long at top of gunwale) have a 1/8 gap between the bottom of the window unit and the fiberglass hull. Looks like the black seal has just worn out and gone away in most places. I thought it screwed down from below the fiberglass, but turns out it's from the top.
I can't figure an easy way to get to the screws as they are in the unit somewhere. I'm thinking I'll just leave them there and get some sealing type caulk in the open space and be done with it.
What product to use for this? 3M 4200 seems well liked for sealing but not so perm i can never remove the window unit. I have 4200 and 5200. Is 4200 a good choice? or other ideas.
Also, a couple snaps for the canvas have pulled out of the fiberglass. The opening is too big to screw it back in so I put 3M 5200 on the snap and set it in the spot where the hole is. a day later and it's not holding in place, Is that too soon? or may I not have used the right product?
Thanks.
Thanks.
