Re: Alpha hinge pins
my merc dealer says that Merc has been elimination them (reduced production costs?)
Not exactly. The new design actually costs more. They have now installed a bushing in the gimbal ring. Before, the hinge pin made contact with the gimbal ring itself. The new bushing doesn't require lube. It actually costs more to manufacture than the older style, not less.
Regarding the grease. You dealer should be using the
Spline Grease for the coupler splines, it stays in place much better than 24C, that is what it was designed for. You can use the
Spline Grease for the prop shaft if you want (the prop shaft is splines to ya know) and eliminate the 24C. But that 24C also has other uses on the engine.
