The boats on a lift so I wanted a full cover to keep the interior dry (the factory play pen cover is mis-designed so that water goes right under it from the windshield) and to prevent chalking of the gel coat on the horizontal surfaces and upper sides.
After a lot of web researching I bought the following from iboat. Their customer service was excellent. The fit of this cover is pretty good (when used with 2 vented poles adjusted very high) and the material extends below the rub rail. The Engine cover fits very snuggly on my 200 Yam.HPDI
The strap set (made by Westland) uses STEEL clips so they will begin rusting immediately (how they can use painted steel on an external marine part is beyond me)
D1423S hurricane sd 237 cover $302.20 Shock cord on semi-custom, by Westland goes 4 beyond rub rail
Sharkskin 5 year warranty; 12 colors available ; 6.5 oz. marine 100% Polyester
Mtr310s yamaha 200 cover $30.00
5050tdbk strap set $19.95e iboat: will attach to mooring cover
5007-5 vented support pole $22.20 iboat: includes vent
I can email pics if anybody needs them.
