I just finished rebulding my ole 3 hp Lightwin with rings, carb rebuild, ignition coils, points , plug wires and water pump. After reassembly and the proper adjustments, the motor fails to fire. After pulling on the cord for a while it did fire but for only a few seconds and not long enough for final needle valve adjustment. I checked the points and coils and they all seem to work fine. But the carb dumps fuel from the carb front when choked, could this be a reed valve problem, I AM STUMPED! Also, how stiff should the motor turn after the new rings and waterpump?
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
I think scaaty is asking about the inlet needle and its seat, not the metering needles, Iron.
The spilling of fuel suggests that the inlet needle is not shutting off the incoming fuel to the bowl when it is full.
Please go to the Engine FAQs read-only forum and do the troubleshooting in "Outboard won't start" to determine which system is not working correctly before going further.
Thanks fo the help, she is up and running like new and i wish that Evinrude would make these again. She is the smoothest running tiller I have ever owned.
