Any Ideas where I might find the caps to hold my fuses in my dash panel? Just purchased a 1975 Glassmaster for renovation and found I was missing 4 of the 5 caps to hold the fuses in. The only one that had a working fuse was the first switch I came to, tracing it from the motor, the power/trim switch. Worked fine, but key would'nt turn the engine. I'm guessing I need those fuses to continue the link across the panel to the key switch? Don't really want to add a new fuse panel if I could find the fuse caps for the original set-up. Any help here would greatly be appreciated. Thanks in advance, Dutchfin
