1994 Yamaha Outboard plugs not firing
gelrod
I have a 1994 40 HP Yamaha outboard and the plugs are not firing. They did this past summer and after sitting about two months it will not start. Battery was bad but when replaced it was found that the sppark plugs are not firing. Any help would be greatly appreciated!
Gelrod
Silvertip
Re: 1994 Yamaha Outboard plugs not firing
Did someone pull the kill switch?
JUSTINTIME
check to see if u are getting votls to the coils also
gelrod
Thanks for the replies. I did check the kill switch. I'll have to check on the volts to the coil. I don't have a meter so I'll find someone who does. Thanks very much!
Gary
JUSTINTIME
u will need a dva to test for volts, and also do ohms check
if u need better instruction e-mail me
Ray Neudecker
A timing light or spark tester will tell you if the plugs are firing.
gelrod
Gelrod
gelrod
again, many thanks for your help!!
Gary
rodbolt
without a model number I cant help much, there were a couple different ignition systems for a 94 40.
other than check inputs and outputs to and from the cdi.
