Re: power tilt problems
degoude, I screwed up and was thinking you engine was a inline 135. So let me start over a V/6 has a manual release but it's on the starboard side of the engine mounting bracket, you will find a hole about 3/4" in dia. the release screw is in that hole it is a slotted screw. It is very common for the center o-ring on the release to blow causing the system to act up to get the release screw out you must remove the E clip that keeps it from falling out, use a small screwdriver go thru the hole and pop it off, then the release screw can be removed thru the hole and he o-rings inspected or replaced. In most cases the E clip won't go back on so in the future you must be carefull not to unscrew the release to far. Sorry about the mixup to start with--Bob
