  #1
Old January 16th, 2007, 12:37 AM
Kajun37's Avatar
Kajun37 Kajun37 is offline
Default 69 evinrude 55hp reverse
my buddy bought a old boat cheap...it has a 1969 evinrude 55hp model # 55973A serial# J04899 and it had no spark.. so he brings it over and we track it down to the amplifier/powerpack...i found him a good used one and we change that out and it started right up..sounds great....shifted it into forward..works good...neutral..works good....put in reverse and nothing happens....it is an electric shift model...the control box has 3 buttons to shift it....
he doesnt have a manual which i have told him to buy a few times.... can anyone tell me some troubleshooting procedures for this problem? i'd like to get it fixed so i can get it out of my driveway...its been here over a week....any info on this would be appreciated.
__________________
Run it till the prop falls off!!!
  #2
Old January 16th, 2007, 05:05 AM
F_R F_R is offline
Default Re: 69 evinrude 55hp reverse
First things first. Check the oil in the lower unit. It is the hydraulic fluid for shifting as well as lubricant. Must use OMC/BRP Premium blend oil. No water allowed in there.
Now, locate the blue and green wires by the powerhead that go down to the lower unit. Slide the insulator sleeves back so you can check the voltage at the connector terminals. Turn the key on and push the reverse button. You should have battery voltage at BOTH green and blue wires. Same thing with neutral button pushed except should show battery voltage at green only. No voltage on either wire in forward. Shift back and forth a few times, switch failure is usually intermittant.
If it fails any of these tests, the problem is electrical, most likely a bad push button switch. They do that a lot.
If it passes the electrical test, the problem is between the connectors and the lower unit, or inside the lower unit.
You DO know that the motor has to be running to shift don't you? But it doesn't have to be running to do the above electrical tests.
  #3
Old January 17th, 2007, 12:56 AM
Kajun37's Avatar
thanks FR...i will try those tips....
i checked the LU it was this yellow oil in it...but it was full...it wasnt milky.....
the motor was running when i was shifting it...it would go in forward and neutral fine...but nothing when i pressed the button to go in reverse....it didnt even seem like it was trying to go in reverse....i'll get out there tommorow and report back what i found.
__________________
  #4
Old January 17th, 2007, 12:54 PM
Dhadley Dhadley is offline
Location: Port Charlotte FL (almost -- its coming along)Never mind - it'll never be the same
Keep in mind this is not an electric shift. It's hydro-electric.
There are two wires going to the lower unit. Follow F R's instructions on how to check the voltage. 12 volts on both = reverse.
You gotta have the right oil too. It wouldn't hurt to start fresh there. Again, follow F R's advise.
  #5
Old January 17th, 2007, 02:07 PM
papasage papasage is offline
the shalft could be stuck in the power head or the shift rod disconected under the bottom carb .
check this titral
http://www.meegsonline.com/tmd/waterpump.wmv
  #6
Old January 17th, 2007, 03:01 PM
I wish it was that simple. Unfortunately there is no shift shaft on a 69 55hp. This is a hydro-electric unit.
  #7
Old January 17th, 2007, 08:17 PM
i know that . i posted that in the rong place . just a wire conection on that . not fermiluar with the 69 have worked on a 1972 . and still have a 1971 on a runabout
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
'69 Evinrude 55HP w/ Selectric switch will not reverse kauboy Johnson & Evinrude Outboards 30 September 1st, 2006 11:28 AM
'79 55hp chry outboard no reverse or nuetral fmgkmg Force & Chrysler Outboards 8 April 26th, 2006 08:29 PM
55hp Evinrude iceburg777 Johnson & Evinrude Outboards 1 March 20th, 2005 06:48 PM
Evinrude 55hp Rob31 Johnson & Evinrude Outboards 6 March 17th, 2003 12:17 PM
55hp Evinrude alarm Arnold Brouwers Johnson & Evinrude Outboards 7 October 31st, 2001 03:11 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
