59 johnson 50 hp super sea horse
HunterNc
I recently purchased a boat with the 59 on it and i am trying to get it running and i went through the engine and carb. i replaced the fuel lines and the pump lines. i removed the belt drive from the distibutor to check the breakers and i was wondering if the engine and distributor had any timing marks on them. i replaced the coil and the wires and cleaned the rest of the parts and i got a spark but i want to get the timing right. any helpwould be greatly apreciatted.:/
Joe Reeves
Re: 59 johnson 50 hp super sea horse
The rear portion of the manual starter housing has a timing mark as does the flywheel and the top of the powerhead. Line all three of those marks up.
Now, on the port (left) side of the magneto, there is a mark on the housing which is pretty well centered with the safety switch, a timing mark on the pulley, and possibly a timing mark on the movable portion of the magneto. Line those marks up, then install the timing belt.
Tighten the belt so that there is a slight bit of play. That's it.
HunterNc
thank you for the help. i will get that all squared away and try to get the engine started. i will post again if i have any other problems.
