If it is similiar to the Zebecs then inflate everything except the keel so the boat barely has air in it but has form. Then put the bow floorboard in as well as #2, 3 and 5. Then take #4 and slot it into #5 (stern) and raise #3 and 4 into a teepee for lack of a better term. Fit the slots together and then press down til flat. Then take the stringers and roll them into place on both sides of floorboards. Pick a side chamber and inflate it to 2 psi, then bow, then other side. Then repeat the process to max out the psi to 3.5. This allows the diaphrams between the chambers to properly inflate. Last inflate the keel. I use a 12v electric pump with adjustable psi as well as auto shutoff when you get to set pressure. Much easier than foot pump.
Quote:
Originally Posted by jmingst
Just purchased an Avon R280 with wood floor boards. I cannot get them to fit in, what is the trick?
Is there a specific order they are installed?
Should the boat be inflatted or deflatted when installing?
Cannot get the boards to interlock.
These are the original Avon floor boards not a reproduction.
Thank you for any help you can give me.
