- May 19, 2001
- 26,112
ZmOz you stated in another thread "I have a B&S master service technician certification, BTW... " http://forums.iboats.com/bbBoard.cgi?a=viewthread;fid=37;gtid=1159060
I need your skills/input.....
I did my final cut for the season on my lawn and the snow will be coming
Time for serious engine maintenance. This year I already rewelded my deck and changed the bearings.
My mower has a Briggs & Stratton 18.5 hp and it is doing strange things......
Idle is very unstable and it surges.... ? New fuel filter, plugs, air filter every season. On the rarest occasion I will be cutting grass and the engine will smoke for 30 seconds and run like garbage then it recovers and smoke goes away and it returns to normal.
I am not sure it is reaching optimum RPM's and have considered a tach to test it. What should the RPM's be at WOT? Should I consider changing the spring ? What color should I get? Which color allows higher RPM? The Parts List has a few and then states "consult a technicion..."
My manual states to remove combustion deposits every 100-300 hours and the manual states to use new gaskets and new shields? Why the shields?
Should I consider a valve job? What should I be looking for on the valve seat or is it replacable?
And the last question..... can I boost the charging system or service it? The mower only charges the battery every other time I use it?
