  #1
Old January 6th, 2007, 06:59 PM
G Walker G  Walker is offline
Default 1985 50hp evinrude ignition problem
My 1985 50 hp evinrude seems to be (click click click) under the flywheel when i turn the key to try and start the motor. What could cause this? I have put a new starter and solenoid on,but didn't fix problem.
  #2
Old January 6th, 2007, 11:39 PM
JUSTINTIME's Avatar
JUSTINTIME JUSTINTIME is offline
Default Re: 1985 50hp evinrude ignition problem
starter solenoid?
maybe bad battery connections
maybe bad starter wire
maybe bad starter ground
time to uses a test light or meter to find out
__________________
HUMAN BUILT = HUMAN FIXED
CERTIFIED MARINE TECH
  #3
Old January 6th, 2007, 11:40 PM
R.Johnson R.Johnson is offline
Check to see if the stator bolt's under the flywheel have backed out.
  #4
Old January 7th, 2007, 07:56 AM
reeldutch's Avatar
reeldutch reeldutch is offline
does the starter turn over or not at all?
if not
check for fully charged battery
all good cables and connectors
clean grounds and tight.
if all looks good and you cant find the problem,
jump the starter directly to see if the starter is ok.
if the starter turns over you have either a bad solenoid or bad connections.
  #5
Old January 7th, 2007, 08:03 AM
Thanks for the responses. I will give all those ideas a try. I replaced the starter and solenoid because they were still original parts and felt it was time to do so anyway. When I shut the motor off in the river and it wouldn't restart ,it just prompted me to go ahead and get r done.
  #6
Old January 11th, 2007, 09:03 PM
Turns out the ignition switch was ok. starter ok. wiring ok, but the BRAND NEW solenoid was no good. Go figure ,but it happens. Thanks for all the help
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
ignition problem 1985 8 hp johnson b sullivan Johnson & Evinrude Outboards 1 April 4th, 2007 02:13 PM
1985 Yamaha 150 ignition problem kerrymc1 Yamaha & Suzuki Outboards 5 October 27th, 2006 05:09 PM
1985 85 hp force ignition problem t.martin Force & Chrysler Outboards 0 April 28th, 2005 07:46 AM
1985 Mariner 50hp 4cyl - engine problem David Cordry Sr. Mercury & Mariner Outboards 2 April 14th, 2003 12:42 AM
1984 50hp merc ignition problem fishingdailycatch Mercury & Mariner Outboards 2 August 24th, 2002 03:21 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
