  #1
Old January 4th, 2007, 09:11 AM
wseith wseith is offline
Default 1968 85 hp evinrude with electric shift
OK, i have tried everything i know to get this motor to run smooth.Unfortunatly i dont know that much. Here is what i did so far. Rebuilt carbs,replaced powerpack and coil,set points,troubleshooted fuel pump per manual and so on. The motor when started up for about 10 seconds runs smooth. After that it starts missing and coughing and it smokes pretty bad.My compresion is about 105 on all cylinders oil is leaking from gear box.I have spark on all cylinders i have a vented gas tank and new gas mixed at 24:1. I dont know what to do next. Ive never had this boat on the water. I am running it in a barrel of water with the shaft approx. 2 feet submerged and the barrel is about 3'x3'. It seems that the engine is running rich and coughing on its own exhaust. Could the way i am running it cause this. Well as you can see im frustrated and about to pitch the engine. If anybody has any advice on where to go from here it would be much appreciated.
  #2
Old January 4th, 2007, 09:29 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: 1968 85 hp evinrude with electric shift
1964 and later are 50 to 1 mixture. have you done a link and sinc? how have you adjusted the carbs. do you have a good manual
carb adjustment:
http://www.iboats.com/bbboard/bbBoar...;gpid=8 18802
manual:
http://www.kencook.com/evinrudejohns...ors&orderby=hp
there are 4 manuals for your year, clik the model number and it will give you the correct manual number, and you can look on ebay.
after getting it running do a decarb on the engine as it probably never been done.
http://www.boatsetup.com/Decarb_Carb.html
ya'll were typing whil i was putting this together.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
F_R F_R is offline
YES! The way you are running it. Right off the bat, it is not supposed to be running on 24:1 It is supposed to be 50:1 So you have a bunch of excess smoke and plug-fouling oil.
Secondly, running in any kind of tank causes smoke to be sucked into the motor intake, which causes rough running. Even the well vented commercial shop tanks usually require running with the hood off. Try blowing the smoke away from the motor with a large fan, might help some. But the real answer is get it on a boat in the water.
If you want to pitch the motor, strap it on a pallet and send it to me.
  #4
Old January 4th, 2007, 09:33 AM
Quote:
carb adjustment:
manual:
Ive ran it on different mixtures from 50:1 to 24:1 im not sure how to do a linc and sinc and my manual is a seloc
  #5
Old January 4th, 2007, 10:08 AM
DHPMARINE DHPMARINE is offline
10 seconds of running good then bad is hard to diagnose.You can do longer than that with a full carb of gas.and it will run 3 minutes or more without water (yes damage will be done to the water pump,but it'll run).
Are you aware of the manual overide on your electric choke? Three settings.
DHP
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1968 johnson electric shift exhaust invader_1230 Johnson & Evinrude Outboards 4 August 17th, 2005 08:08 AM
Evinrude 1968 55hp hydro-electric shift problem gdwoods Johnson & Evinrude Outboards 7 October 29th, 2004 07:09 AM
1968 55hp evinrude electric shift wenzel Johnson & Evinrude Outboards 5 August 30th, 2003 06:36 PM
Johnson 55hp 1968-Hydro Electric Shift wdudley Johnson & Evinrude Outboards 2 March 10th, 2002 05:15 PM
1968 85hp Evinrude Electric Shift not getting spark on plugs JohnD90472 Johnson & Evinrude Outboards 10 July 19th, 2001 07:10 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
