Hi everyone,I'm new here and would like to pick your brain's!
I reciently bought a '85 evinrude 9.9.I am having a few problems with it.First the water comming out from the large pee hole in the center of the leg directly below the motor is very hot,and the water coming from the motor cooling pee-hole is very weak(little more than a drip).I was under the impression that the hot water may be caused by a faulty impeller,but it has been changed right before I bought it.Although I am sceptical about this as the water spray's out instead of a steady stream.
Second,after steaming out to my favorite fishing spot,and killing the motor while I fish,when I start the motor again it wont stay running long enough to put it in gear to come home?Is this a carb problem due to exess fuel filling the bowl and thus flooding?
Dont mean to ask such rookie question's but I keep getting 20 different awnsers when I ask the experts around here,ie the water is supposed to spray instead of a steady stream.
thanks
Aaron
thanks
Aaron
