Boomyal
- Aug 16, 2003
- 12,072
Is the bolt that hold the anode steering tab on supposed to come all the way out of the hole you put the allen wrench into? It seems that the bolt might have been installed before the upper and lower housings were mated. But maybe it is just a corrosion issue that keeps the bolt from being removed. I did not have any trouble unscrewing the tab but I would like to remove the bolt to run the threads over a wire wheel.
