  #1
Old January 1st, 2007, 10:39 PM
rajabatis rajabatis is offline
Default EVINRUDE 92 50 LOWER UNIT OIL DRAIN AND REFILL QUERY
Hi, I'm new to boating and have just got my first boat. I'm working on getting the engine, (Evinrude 50 year 1992) in good shape for spring.
My query is I want to change the oil in the lower unit but I am not sure were the oil plugs are.
Is the fill up plug the one with the angled allen key plug at the top and is the drain the angled regular slotted screw at the bottom of the lower unit to the upper side behind the prop housing?
Both of these - if they are the correct ones? Are in very tight and I can't budge them.
Sorry to appear dumb but as I said I'm a newbie and I have no manual to refer to. Any advice would be appreciated on finding the right plugs and how to get them out and how much oil and type to put in?
Thanks in advance.
  #2
Old January 1st, 2007, 11:13 PM
OBJ's Avatar
OBJ OBJ is offline
Default Re: EVINRUDE 92 50 LOWER UNIT OIL DRAIN AND REFILL QUERY
Both Vent and Drain/Fill plugs should be large slotted head screws. The drain plug is on the bottom of the gear case just about where the skeg meets the gear case. The vent plug is just above the anti-cav plate...that's the plate right above the prop.
Both are on the starboard side of the gear case.
Drain the old lube out by removing both Vent and Drain plugs.
Fill the gear case from the bottom up until the lube comes out the vent plug hole. Fill slowly so the air has a chance to be pushed out.
Here's the link to the BRP site. Start in the upper left corner where it says "Product" and hit "GO". When you find your model engine, hit the "Gearcase" view. Look for parts 6 & 10.
http://epc.brp.com/(X(1)S(2kjd5w452cjslm45d4ivuk45))/login.aspx?ReturnUrl=%2fdefault.aspx%3fbrands%3dej %26lang%3dE&brands=ej&lang=E&AspxAutoDetectCookieS upport=1
Recently....like in the last year or so, BRP introduced a new style plug for the vent and drain plugs. This new plug has an Allen Head in it instead of a slot for a screw driver. I'm including this in the chance the previous owner changed one to the new style.
__________________
When in doubt...use the manual
Rayland, Ohio....Along the Muddy Banks of the Mighty Ohio River.
  #3
Old January 2nd, 2007, 08:15 AM
Thanks very helpfull! I found them.
  #4
Old January 2nd, 2007, 11:04 AM
Silvertip Silvertip is offline
Use a "quality" allen wrench and for the slotted screw, use a "large" screwdriver. Using poor quality tools results in slots that are rounded out and allen wrenches that simply break or round off. You are aware that you fill the lower unit from the bottom until lub comes out the top? Then insert the lower plug followed by the top plug. WalMart has a simple pump that makes the job easier.
  #5
Old January 2nd, 2007, 02:39 PM
Cricket Too Cricket Too is offline
I always thought you put the Top plug in first, after the oil comes out, then the lower plug?
  #6
Old January 2nd, 2007, 05:28 PM
LORDY611's Avatar
LORDY611 LORDY611 is offline
Quote:
I use one of those WalMart type pumps that threads into the lower hole. When the oil comes out the top, it wastes less if you just screw in the top one to create a vacuum so that when you unscrew the pump the oil doesnt come rushing out.
  #7
Old January 2nd, 2007, 07:22 PM
DHPMARINE DHPMARINE is offline
Silvertip, I am agreeing with you on the tool usage,and have noticed the same rounding off you mention.BUT when not using quality tools,why do the slots and allens round out? The tools should fail.
The drain plugs should be better quality.
Why BRP went to allens ..........
DHP
  #8
Old January 2nd, 2007, 08:31 PM
Slotted screws it was, but needed a good deal of force to get out. They don't look as though they had been out for some time. Alan heads would make a lot more sense though. Luckily the oil was in good condition. I topped it up by removing the top one then pumping in the new oil via the bottom one. Worked out fine.
  #9
Old April 18th, 2007, 08:40 PM
digital digital is offline
I just changed the gearcase oil in my 93 Evinrude 30, I drained the lube from the bottom drain plug, closed it and then filled from the top screw.
What a pain this was, I'm not sure if I did it correctly. Anyways I filled it until I could see that the oil was up in the top screw, is it full?
It called for 11oz but I'm sure it didn't drain that much. I just want to make sure I'm not going to mess anything up when I run the motor next time out.
Thanks
  #10
Old April 18th, 2007, 09:12 PM
Digital -- didn't you read this post? Fill from the bottom!!
  #11
Old April 18th, 2007, 09:20 PM
Actually I didn't read it before changing the oil, I did read my service manual and it said nothing about filling it from the bottom..
If the bottom is the drain plug, won't the oil just come out??
  #12
Old April 18th, 2007, 10:02 PM
Ok I just drained it again, looks like I'm going to have to do it again, better safe than sorry.
The Evinrude gearcase oil I got comes in a squeeze bottle? Do I need something else with a pump?
Thanks for helping.
  #13
Old April 19th, 2007, 07:09 PM
NealLauderman NealLauderman is offline
Thanks for helping.
Digital, you dont "need" a pump. I just did mine the other day and my bottle had a little tip on it. I just shoved it in the bottom hole and squeezed till it started ooz'ing out the top. I notice on here they say to put the bottom screw in first, I put the top in first. Dont think it would matter too much but the manual says to the bottom screw first too... so I reckon you do it that way. I read the manual afterwards... stupid me.
  #14
Old April 19th, 2007, 07:24 PM
JB's Avatar
JB JB is offline
The most common mistake when changing gearcase lube is to not use new gaskets on the plugs.
ALWAYS use new gaskets. They crush, like plug gaskets, and are not reusable.
__________________
RED SKY at night. . .
JB
  #15
Old September 19th, 2009, 04:29 PM
watt476 watt476 is offline
thanks JB, OBJ, etc.
I was having trouble with this too, now I know what to do.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
How to drain lower unit mrbuckaro Force & Chrysler Outboards 4 August 19th, 2005 04:40 PM
lower unit drain hole cbsykes Yamaha & Suzuki Outboards 6 April 5th, 2005 08:02 PM
lower unit drain and refill--flush? Motor Boater Bill Mercury & Mariner Outboards 8 March 4th, 2005 11:45 AM
88' 70HP Evinrude Lower unit drain/check plugs scott324 Johnson & Evinrude Outboards 1 October 29th, 2004 03:02 PM
Lower Unit Drain FreeBeeTony Non-Repair Outboard Discussions 8 November 15th, 2002 04:31 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
