Checking Trailer on New Project Boat
MelLandry
I cross posted this in the boating restoration forum because I thought they may have some experience with well used trailers on well used boats.
I'll be picking up my new project boat soon (late 70's 24 ft Stamas).
Before then (maybe today), I'll be going to take a look at the trailer to ensure it's ready for the 120 mile trip to my house.
Can anyone give me a rundown on what I should check? Feel free to assume I'm as ignorant as a rock.
I assume the most attention should be paid to the hubs. I plan on jacking up the trailer, checking that the wheels spin freely, and that there is no rocking motion when pressure is applied to laterally to the tires.
Any other suggestions?
Silvertip
Re: Checking Trailer on New Project Boat
Listen for a rough or grinding sound as you spin each wheel. Thats a sign of a rough bearing and I would not attempt a 120 mile trip unless its repaired. Don't confuse that with brake drag if the trailer has brakes. Make sure the tires are aired up properly and that the lights work. If it has surge brakes, make sure the brake fluid level is correct. If the fluid looks rusty or the resevoir is empty, there are some serious brake issues that will need attention. Simply adding fluid will likely not bring the system back to life. Good luck with your project.
bruceb58
If it is also a late 70's trailer, you can pretty much assume the brakes will not be working unless work has recently been done on them.
Trailer brake master and wheel cylinders will only last a few years if they aren't being used.
