Re: 75 Johnson Rocks Back and Forth
There should be no reason why you cant do the job.Especially the lower ones ,which I again suggest doing ,to buy you some time,leaving the top to later.If you decide to go for the top,check the powerhead bolts to see what they are like,remove the cowling piece,this exposes the bolts. They should have a 1/2 inch head.Use a 6 point socket or wrench and see if they will budge.If those bolts will loosen.you job is a piece of cake,if they are stuck,dont break them,ask for some more hints.I have some good ones
