  #1
Old December 31st, 2006, 03:45 PM
judavis126 judavis126 is offline
Default Mercury 1965 9.8 HP: Need HELP with lower unit removal
I am trying to replace the impeller on my 1965 9.8 merc. I removed the 2 nuts holding the lower unit on. I got it down about 3/4 in. It will not go down any more. Am I missing something else. I have looked to try to unhook the shifter rod but I cant figure out how. Do I need to even unhook it? If it is all unhooked should I try to pry on it some how or what would you do?
Thanks
  #2
Old December 31st, 2006, 03:52 PM
WillyBWright's Avatar
WillyBWright WillyBWright is offline
Smell our Dairy Air.
Default Re: Mercury 1965 9.8 HP: Need HELP with lower unit removal
It should drop off. The water intake screen under the antiventilation plate probably needs to be coaxed. The tab that goes onto the stud likes to grab threads as the gearcase drops. Push it forward with a screwdriver.
__________________
Hey, Have you seen? They make Really Cool life preservers nowadays.
So "Looking Dorky" is no longer an excuse for not wearing one.
  #3
Old December 31st, 2006, 06:04 PM
The bolt studs are past that point. The lower unit moves up and down about 1/4 in. Its like it hits a point and just will not go any further. I put some rubber in between the crack and then pried down but it will not budge past that point. How is the shifter rod and the drive shaft connected? What about taking the motor off then I could check out the rods inside the case. Any ideas will help.
Thanks
  #4
Old December 31st, 2006, 07:22 PM
Laddies Laddies is online now
I have seen the shift shafts on some of the older 6,7.5 and 10 HP engines rust to the point they won't seperate without prying on the unit till you pull the lower shaft out of the lower case then the gearcase has to be disassembled to put the shaft back in, you might seek some help from a marina
__________________
PLEASE, no service questions in PMs thats what the forums are for.
  #5
Old January 1st, 2007, 01:08 AM
Is there a way to disconnect the shift rod at the top and then pull the complete rod out with the lower unit.
Anyone have an idea what it cost to get a marina to change an impeller?
Thanks
  #6
Old January 3rd, 2007, 02:51 AM
TriadSteeler TriadSteeler is offline
Disassembling the shift mech. from the top down would be more work than it is worth.
Having to dissassemble the gearcase to reseat the shift shaft is worse (The expense in specialized tools alone is a killer)
My knowledge of the 9.8 is limited, but do they have the bolt underneath the trim anode like its bigger siblings?
Also, peer into the forward end of the lower unit where the separation is. The shift shaft should be right there. You may be able to get some PB blaster in there or get something in there to vibrate the shaft to loosen it (i.e. like a strap placed on an orbital sander).
Whatever you do, DON'T grab the spud bar. Like Laddies said, raw force will pull the shift shaft out from the clutch and because of the spring pressure, it can't be easily reseated.
  #7
Old January 3rd, 2007, 02:53 AM
1 more thing. The marina route to change the impeller is hundreds less than dismantling the gear case.
As far as an actual number, I've heard anything from 50-250 for an impeller replacement.
  #8
Old January 3rd, 2007, 12:36 PM
Harker Harker is offline
I had a heck of a time taking mine off the first time (67 9.8). Make sure it is clamped to something while trying to pull/wiggle it off. The bolts at the front and rear kept mine from sliding off freely. The bolt under the intake screen backed out with the nut the second time I took it off and it almost fell off when I loosened the other nut. You may have some corosion around the bolts that is wedging against the housing..squirt them with PB blaster and let soak and work it up and down to loosen the crud. If it's down 3/4" I'd bet the bolts are jamming in the holes.
  #9
Old January 3rd, 2007, 03:06 PM
I have put a good amount of pressure trying to pull this off and it will not go any further. Is the shaft/rod splined or how do they go together. About how far up are they splined. Were the lower unit is at now it wiggles freely. It will move up and down about 1/4in but I cant cant get it all of the way back up. Is it the shifting rod or the drive shaft holding it on or could it be both.
Thanks
  #10
Old January 3rd, 2007, 04:43 PM
Yes, the lower shift shaft and the driveshaft are splined.I'd say the lower shift shaft spline is about an inch long. The shift shaft rotates left and right to shift..not up and down. Having trouble getting it to close was a problem I had too. Someone gave the tip of setting the motor upside down and twiddling the shift lever until the upper shift shaft receptical was centered in the hole..worked like a charm. I still think you have an issue with the bolts. I didn't say this before..but...I used a 16" piece of 2x4 and a rubber mallet the first time I took mine off..I set the 2x4 on the cavitation fin and smacked it..some on each side till it came off..not recommending you do that but, I was desperate.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
mercury lower unit removal vyger Mercury & Mariner Outboards 9 August 28th, 2006 05:50 PM
MERCURY 90 4-S LOWER UNIT REMOVAL - HELP! normantibbles21 Mercury & Mariner Outboards 2 March 13th, 2006 03:26 PM
1976 4.5 hp mercury outboard lower unit removal enginedude Mercury & Mariner Outboards 1 February 12th, 2006 10:47 AM
2001 Mercury / Tracker 40HP Lower Unit Removal rev.rick Mercury & Mariner Outboards 2 July 14th, 2005 11:36 AM
Mercury 225 HP Lower unit removal Vic D Mercury & Mariner Outboards 4 October 17th, 2003 10:31 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
