JB Weld Success Story
i386
I recently broke my carb control panel. After trying several times to repair it with "super" glue I decided to use J-B Stik Weld.
You can see the crack where it was broke.
The repair is visable only from the back.
I would venture to say if your carb is similar to mine you could go ahead and do this preventatively and never have to worry about it breaking. A new control panel is about $30. The Stik Weld was about $5 I think.
Scaaty
Re: JB Weld Success Story
I've used it on a lot of stuff...works fine!
clint
Sounds like a great product. I will have to get a tube. Thanks!
Clint8)
Scaaty
Actually its been around for a long time. Called Plumbers Putty a long time ago......
Texasmark
Comes in 2 tubes, black and white or black and red depending on whether it is fast dry or regular. Mixes at 1:1 and be ready to get her on fast as in hot weather it will setup in just a few minutes if the fast dry.
Be sure surface is roughed up and clean prior to using. I use brake cleaner to degrease the surface prior to installing. I like Berryman's brand of cleaner. Leaves less residue.
Mark
