  #1
Old December 29th, 2006, 10:47 PM
RLRick RLRick is offline
Default Correct Procedure for Starting 50hp Mariner Motor?
Have just bought a used 1999 16' Tracker with a 50hp Mariner Motor (my first boat). Seem to have trouble figuring out the correct procedure to start the motor. Has a Choke button on console. I'm not sure when/when not to use it...Not sure how much throttle is appropriate? I would appreciate any suggestions or comments from a veteran boater. Ignorance is NOT Bliss!
  #2
Old December 30th, 2006, 03:45 AM
Scaaty's Avatar
Scaaty Scaaty is offline
Default Re: Correct Procedure for Starting 50hp Mariner Motor?
Cold, choke it. Should have some kind of high idle on the throttle ..use it. Warm, turn the key.
  #3
Old December 30th, 2006, 02:30 PM
Silvertip Silvertip is offline
Squeeze the primer bulb until firm. Raise the fast idle lever. Normally the choke/enrichener is activated by pushing in on the key. But if its on the dash, it works the same way. Turn the key to start and push in on it until the engine fires. Then quickly back the fast idle lever down a little. You may have to bump the key (choke) a time or two if the engine has a tendency to die during warm up. Lower the fast idle lever and away you go.
  #4
Old December 30th, 2006, 02:52 PM
Now THAT is what I was looking for. I will keep a copy your procedure in the boat. Can't Thank you enough my friend . . .
  #5
Old December 31st, 2006, 05:54 PM
Solittle Solittle is offline
That is a universal procedure but not cast in concrete. Seems some outboards have a personality all their own. You will find what works best for your engine.
  #6
Old December 31st, 2006, 07:16 PM
I assume that is a given. You have definately hit the nail on the head when you said that some outboards (like mine) have a personality all their own. I have been contemplating naming my motor "Knot Head" as it tends to do as it pleases.
Would like to be able to do more fishing than fiddling around with getting the thing started.
Thank you and the others for your friendly suggestions, as I can use all the help I can get . . .
New Guy
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
correct timing procedure for 3.0 140? jedimaster Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 July 18th, 2006 06:25 PM
what's the correct valve lash procedure? scottishgold Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 June 10th, 2006 07:15 PM
correct comp test procedure crazy charlie Non-Repair Outboard Discussions 4 March 16th, 2004 07:37 AM
Proper procedure for starting electric start motor? twierz Johnson & Evinrude Outboards 2 May 13th, 2003 12:16 PM
What is the correct procedure for Thunderbolt IV rmoore Non-Repair Outboard Discussions 2 September 25th, 2001 01:22 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
