I have a Wellcraft 18 foot boat with a Mercruiser 470 I/O engine. I took it out last weekend and the boat ran fine all day. However, when we left our last fishing spot, I couldn't get the boat to plane regardless of tilt and trim adjustment. After trying three or four times, I noticed water coming from the engine housing and realized the boat had taken on a lot of water. The storage compartment in the floor was full also. Yes, the plug was in and there are no holes in the hull anywhere. The hull is in great shape. When we got to the boat ramp (towed in because the boat wouldn't stay running due to the water depth in the engine compartment I'm guessing) and I took the plug out, there must have been 500-600 gallons of water in the hull. Does anyone have any idea what could cause this? The only thing I can think of is that water is getting in between the outdrive and the transom but I've never had this problem before and can't see any obvious area that the water would be getting in. By the way, after all the water was drained, the engine started and ran fine. Any ideas would be greatly appreciated!!!
Thanks,
Mike P.
Thanks,
Mike P.
