flyfishandrun
- Oct 4, 2006
- 3
My Tilt/Trim stops working perodically, if I tap on the relays it will start to go up/down again. Today I read a number of posts regarding tilt/trim and traced all of the wires looking for shorts. I did notice a spark emiting from the backside of the bracket that the relays plug into. For the life of me I can not get that bracket out of the holder so I can inspect the wires to try and fix. It appears that grounds are all good and what I see and hear is a spark when I press the tilt/trim up down switch at the motor and tap on the relays. Any ideas on how that bracket will come away from the motor so you can see the wires on the back side. Incidentally there is a large amount of grease on the back side of the bracket.
Any help with trying to fix this would be appreciated.
