ziggy
- Jun 30, 2004
- 7,473
hi folks, got the boat listed below. tihis is the first time i've wanted to change a prop from what i already have. i have a 21 pitch "fan blade looking" prop. i think i have issues when trying to get wot. i can get it, but seems like i have to trim to high to me. when trimmed down where i think i ought to be i get maybe 3900, and can go lower for a wot run if i trim down more(38-37). can get 4100-4200 trimed up high. anyways, i found me a 19 pitch at the dealer, alum also, dealer says it's a mercrusier prop. thought i'd just R&R it. wrong. the 19 hits the trim tab. back to the dealer and now have a thinner thrust washer. cool, not. still hits the trim tab. i'd put my 21 back on but i musta found me something solid on the river yesterday and lost me a tip of a blade. enough that i think i don't want to run it for bein outa balance. so...... i had a 17 alum. around and put that on. thin thrust washer and it does fit. but man, is it close to the trim tab. end play on the propshaft is round abouts 1/32"- 1/16".
question is i guess. are there special props designed to be used with that mighty long model I trim tab? i was gonna R&R that too, but bet i will be meltin that off if that's what i want as i have started to strip the drive on the trim tab bolt...any one have any ideas?
