Hi all,
I have a 4 cylinder 2 carb classic 50. Was running fine on a skiing run then all of a sudden stalled at low speed and now will only start for a moment then stops.
I started with the tank and fuel, filters and lines. Then moved on and rebuilt the carbs and fuel pumps with new kits. Then checked the timing and the compression.
I have a fair bit of experience with these engines and never had a problem i cannot get to the bottom of before, but been at this over a month and now totally stuck and frustrated!!
Any help and guidance much appreciated. It will start pretty much right on the key then run for 1-5 seconds and die off very quickly. For the short period it runs it sounds like it is firing on all 4 fine.
Jeremy
Jeremy
