Re: Boat pulls left
dbric;
Let's assume that you are getting the pull to the left at crusing speed.
Let's also assume that it is steering and not a list to port.
Look at your steering tab on the bottom of the anti ventilation flage directly above the propeller.
If you are talking about a list to port as well as a tendancy to steer in that direction , then I would suggest you look at the Hydrofoil (if you have one) and remove it. Your list is from two issues. One is the prop torque especially if you have a stainless steel prop, and two the hydrofoil will exagerate the list because it lifts the boat too much once it is on plain, driving the bow down.
If you have no hydrofoil, then my question would be are you trimming the motor up once you are at cruising speeds? If not do so and see what happens.
