  #1
Old December 17th, 2006, 06:04 AM
bobwells bobwells is offline
Default '89 yamaha pro v 150 carb trouble
My trouble started with top & bottom carbs flooding, (pouring out fuel from front of throats) at idle. I ordered new kits replaced needle and seats, floats, etc. fired her up yesterday same deal, fuel just pouring into the top & bottom carbs, they are single float carbs, best i know how floats are set level to the eye, they seemed to be sealing off good with needle in closed position, any ideas on what to look for? thanks, bob
  #2
Old December 17th, 2006, 10:41 AM
Ray Neudecker Ray Neudecker is offline
Default Re: '89 yamaha pro v 150 carb trouble
The 89 models did not have single bowl carbs. Are you using an electric fuel pump? Did you clean the carbs before installing the kits?
  #3
Old December 17th, 2006, 05:36 PM
JUSTINTIME's Avatar
JUSTINTIME JUSTINTIME is offline
does this motor have recirculation valves?
fuel running out of the carb would be a good indication for this
__________________
HUMAN BUILT = HUMAN FIXED
CERTIFIED MARINE TECH
  #4
Old December 19th, 2006, 01:23 AM
I bought the engine used, was told they "thought it was '89"... could be older, or carbs could of been changed. I used it all summer with a little load up at idle, but not really any trouble, I live on a lake so it got run quite a bit. I do not run electric f/pump. As for cleanig i took them apart and sprayed down good w/ carb cleaner. I dont know what a recirculation valve is?... not an outboard mechanic,just having to learn due to high cost of labor. Use to hot rod cars so have some mechanic ability.?.. :-) also as for adjustments I guess would be called jets. They were just over 1-1/2 turns out so I set new ones at same place, is this correct? I know the carbs have definetly been into before by looking at screws etc... thanks for the help you guys provide everybody, and Merry Christmas !
  #5
Old December 19th, 2006, 02:15 AM
JUSTINTIME's Avatar
Default Re: '89 Yamaha pro v 150 carb trouble
try to get a factory manual
follow the lines on the carbs
there might be recirculation valves on them, i just do not know
ray or rodbolt should know
__________________
  #6
Old December 19th, 2006, 07:47 PM
The single bowl 220 carbs were a favorite hop upon those motors. They were about 30 Hp more than the very restricted 150 ones.
There were a couple of kits for those carbs but every thing will interchange including float bowls as different as they look.
You are first going to have to do the carb job correctly. You need to dissasemble, soak in carb cleaner, wash out with hot soapy water (better halves will show you what tough is if you do it in her sink) and blow dry. Reassemble with new needles and seats and gaskets. Check the float heights.
The air idle adjustment according to the factory was 1 1/4 from a soft stop, I always preferred 1 1/2.
  #7
Old December 19th, 2006, 10:26 PM
Is the carb cleaner you say to soak them in a product I can by at an auto parts store? Any particular brand? Also how do I know what the float height should be set at? all i know is eyeballing level... thanks Ray
you know anything about this recirculating valve thingy?
  #8
Old December 19th, 2006, 10:31 PM
JUSTINTIME's Avatar
the napa stuff works the best
14mm-16mm i believe is the height of float
__________________
  #9
Old December 20th, 2006, 10:42 AM
I'll take justintimes word for the NAPA even though I haven't really found any difference in the results from a specific brand. The 14-16mm is fairly normal for Yamaha carbs. Have never seen the recirculation cause this problem.
One step at a time. Get those carbs right first.
  #10
Old December 20th, 2006, 11:18 PM
talked to a buddy today who works on motors, said the reed valves might be broken,burnt, etc. I told him the fuel seems to be coming down from the top of carb in a heavy spray/drizzle. I gotta pull carbs to ck this also, may have to "dig a little deeper in the well" if cleaning dont do it. He said I could partially see reeds with flashlight with carbs removed, may pull intake while carbs are off and check reed blocks. does this sound feasible ? (the reeds) I'll keep you posted, may be sat. b-4 i have time to shadetree again. thanks again, bob
  #11
Old December 21st, 2006, 09:26 AM
Normally reed problems will result in backfiring out of the carb. You can look at them with a flashlight when you pull the carbs off to be sure.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Carb trouble HELP piermanp Mercury & Mariner Outboards 4 June 6th, 2005 10:33 AM
carb trouble mikelittleg Johnson & Evinrude Outboards 1 May 27th, 2004 08:19 PM
carb trouble mikelittleg Johnson & Evinrude Outboards 1 May 27th, 2004 07:16 PM
carb trouble IVAN QUINTANA Johnson & Evinrude Outboards 1 May 27th, 2003 05:42 AM
carb. trouble taz33911 Johnson & Evinrude Outboards 1 August 20th, 2002 04:14 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
