I just picked up a mid 70's 9.9 at a yard sale. I got it home and it fired right up and seemed to run properly. The only thing is I think the throttle is abnormally hard to twist.I am nearly a "novice" outboard tech.I have tinkerd with a few outboards though. What I would like to know is, should I just lube the moving parts? Is there a certain type of lube to use? and Is there a suspect part that may be worn causing the tightness that I cant see?
Thanks, Chris
Thanks, Chris
