  #1
Old December 15th, 2006, 10:39 PM
mclamown mclamown is offline
Default Yamaha cooling system
Ray and Rodbolt thanks for your help on the yamaha. Though I would share what was found after the heads were taken off. The head cover gasket on the port side had a hole in it letting water bypass the thermostat. The star side had a partially plugged drain hole the reason it was hot. I noticed the cylinders on the cold side has some scatches on them. Was this caused from it runnimg cold on that side,the hot was ok. Thanks Mike
  #2
Old December 20th, 2006, 10:45 AM
Ray Neudecker Ray Neudecker is offline
Default Re: Yamaha cooling system
Scratchs are normally from one of two sources. Debris or foriegn matter in the cylinder or light siezure of the piston,
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
rod bolt: v6 2000 carb yamaha cooling system fow path mclamown Yamaha & Suzuki Outboards 5 December 14th, 2006 09:24 PM
cooling system twinsburg Johnson & Evinrude Outboards 1 June 10th, 2004 10:32 AM
Merc 850 (85hp)How to check/clear cooling system of items plugging system. sailor Mercury & Mariner Outboards 3 April 22nd, 2004 09:48 PM
cooling system corrosion in 90 Yamaha rustymed Yamaha & Suzuki Outboards 3 April 25th, 2003 05:43 PM
'82 Yamaha Waverunner Cooling System krimsun36 Yamaha & Suzuki Outboards 0 June 11th, 2002 07:43 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
