Quote:
Originally Posted by rodbolt
without looking at the block and all my marine tech guides are packed away I can say other than the water come up from the bottom. flows around the cylinders, then out through the T-stat and back down the water jacket then it exits the block via the powerhead adapter.
maybe Ray can describe it from memory. but I still think your dealing with a scale build up in the water jackets.
Thanks for reply . The scale is not the problem it is fairly clean. The power head adapter is not on this one or ijust don,t see it. The Johnsons used a rubber hose to bring water in then it drained out the bottom. Think will pull the other head a have a look it was not getting hot. Thanks.
