  #1
Old December 10th, 2006, 10:02 PM
imported_Cpt_Quint imported_Cpt_Quint is offline
Default 18' Bluefin Aluminum Transom Repair
The old wood is out and I have found a new problem. The aluminum had salt trapped between the transom wood and the inner and outer skins causing major corrosion and pitting. :^ I will replace the inner aluminum skin, but the outer skin needs to stay because I feel replacing it will be cost prohibitive.:|
I would like to repair it by filling in the pits, repainting, and adding a over sized aluminum outer transom plate.
What should I do to stop any further corrosion and repair what is left of a mostly usable transom outer skin?
http://img.photobucket.com/albums/v7...ansomWood2.jpg
http://img.photobucket.com/albums/v7...Corrosion1.jpg
http://img.photobucket.com/albums/v7...Corrosion3.jpg
Let me know what you think....please
  #2
Old December 11th, 2006, 07:43 AM
Bob_VT's Avatar
Bob_VT Bob_VT is online now
Default Re: 18' Bluefin Aluminum Transom Repair
It has to be cleaned to bare aluminum (completely) treated and I would coat it. Adding an additional plate is a good idea and I would seal between the plates with an epoxy. Devcon makes an epoxy for aluminum but gluvit will work fine in a cleaned surface.
I would use Gluvit to coat and between the pieces.
On a side note..... get a price to have a new thick piece welded in.
Once you are ready to mount the new wood I would also suggest using more gluvit or even gease (maybe a light coat of 3m 4200 but that would be exspensive too).
Any bolts or fasteners that pass through the wood and aluminum NEED to be stainless AND coated befor insterion with grease or 3m 4200.
__________________
"When you see yourself doing something badly and nobody’s bothering to tell you anymore, that’s a very bad place to be. Your critics are your ones telling you they still love you and care." Randy Pausch 1960-2008 The Last Lecture
SpinnerBait_Nut's Member Map Link Please add yourself http://www.frappr.com/iboats
  #3
Old December 11th, 2006, 03:07 PM
joblo33 joblo33 is offline
Wow, deja vu! Yours looks a lot nicer than mine did though.
http://www.boatbuildingonline.com/fo...opic.php?t=487
As you can see I solved it by putting a 3/16" sheet of aluminium on either side and bolting them together with some autobody sealer squished in between the layers. I also took this opportunity to change my boat over to long shaft.
Eric
  #4
Old December 11th, 2006, 06:36 PM
Oh my...Nice job on your transom. How did you make the swirl pattern on the back? A sanding wheel maybe...I like it.
  #5
Old December 11th, 2006, 08:35 PM
Thanks.
I used a random orbit sander for the swirls. Aroliner boats originally had that finish on the entire exterior, but they've worn off on mine. This spring I plan to redo them with the sander and put a couple layers of clear coat over everything to keep them from corroding.
Eric
  #6
Old December 11th, 2006, 11:32 PM
Bob,
Great advise...I will be using Gluvit as suggested. The new plywood will be coated with several coats of epoxy (MAS or West Systems) before dropping it in. Does Gluvit bond to epoxy? Both will be cured before coming in contact, but then these two materials will be pressed together for a long time.
After the new aluminum inner skin and the prepared plywood are inÂ… how would I best seal the top before the new cap is put on? Epoxy? Maybe more Gluvit?
Trying to think aheadÂ…
  #7
Old December 22nd, 2006, 07:53 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
suggest making a pattern after getting the transom in. take it to a tin bender, you'll never find a matching piece. probably the most expensive part of the repair.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #8
Old December 22nd, 2006, 08:24 AM
woody20 woody20 is offline
Cpt,
Go to a metal shop, or even a trade school (weld shop) and see if they will tig on new metal over the whole transom. The trade school might do it for the price of the metal and cheap labor from the kids, and don't worry the teach should check the welds that the kids did.
  #9
Old December 22nd, 2006, 11:33 AM
Bond-o's Avatar
Bond-o Bond-o is offline
Master Shipwright
Ayuh,..........
Gluvit IS Epoxy,....... with powered Aluminum filler......
__________________
Any Grease is Better,..... Than No Grease at All.......
NO PM's (Private Messages) regarding boat/engine problems. That is what these forums are for.
They will be Deleted
  #10
Old December 28th, 2006, 03:34 AM
The new transom wood and inner aluminum skin are installed. It's rock solid now.
Question...where can I buy new transom trim?
I coated the entire hull with Gluvit (epoxy).
  #11
Old December 28th, 2006, 07:27 AM
the trade school sounds like the best idea. then start calling metal shops. it's going to take someone who know what the are doing to make those bends.
__________________
FLORIDA GATORS
TEBOW Country
  #12
Old December 28th, 2006, 09:11 AM
Looking good Cpt.!! keep it up, it will be fishing time soon. That boat would be a really good cape cod bay boat up here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
18' Bluefin Aluminum Rebuild Restoration imported_Cpt_Quint Boat Restoration and Building 16 December 21st, 2006 11:25 PM
Aluminum Starcraft transom repair? KilroyJC Boat Restoration and Building 39 August 15th, 2006 08:51 AM
Aluminum transom repair?? b.gagnon Boat Restoration and Building 1 March 18th, 2006 06:17 AM
Aluminum Repair Wimperdink Boat Restoration and Building 0 September 4th, 2005 09:20 PM
Transom worry 1969 Savage Bluefin 23ft j_jtaylor Boat Restoration and Building 8 October 23rd, 2004 07:37 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
