pecheux
- Jun 9, 2006
- 1,200
Hi y'awl
I have read many post recommending newcomers NOT to use a 100:1 mix in outboards. Now most oils nowadays shows the possibility of mixing at 100:1
I can understand that oil that was originaly made for 50:1 mix motors should not be used at 100:1 mix in those same engines.
But my question is ... are all those NO NO 100:1 mix concern these regular oils ? or does it also include Amsoil type oil (or others) that were originaly designed to be used at 100:1 as per their saying to be used in engine that would normaly require a 50:1 mix with regular 2 cycle oil.
I know this subject was on the table in the past ... but this one stands out differently.
Tx
Tx
