Clearing
SeaQuin
I have a 1992 Johnson 9.9 long shaft that I use on my 27 foot sailboat in salt water. I make an effort to flush the motor with each use but find the "pee-hole" plugs very easily with salt. The engine isn't running especially hot and I have had it checked so it isn't a water pump problem I think it's just the design of the coolant indicator line. Has anyone found an easy way to keep that line clear. I still like to see a nice stream coming out...makes me feel better.
Thanks for any ideas.
imported_lorin
Re: Clearing
Not only can the hose get plugged up, but also the plastic nipple the hose attaches to (if this motor has a plastic nipple). So pull the hose off the nipple and poke a paper clip into the nipple to clear it out if you haven't already done that.
SeaQuin
Re: Clearing of "Pee-hole"
Yup, done that, even tried putting a guitar string down the hose, but there is a silly right angle that stops that from working.
ezeke
Re: Clearing
If you copy the following link without the quotation marks to your browser, then scroll to the bottom of the page, you will find a wealth of information relative to your motor.
One of the things that LeeRoy Wisner suggested was to drill a cleanout hole through the square end of the tell tale fitting and then put a screw in it. I liked the idea and used it.
"http://www.wisnersinc.com/Fishing%20Info/Fishinginfo_main.html"
