Is it normal to have a little play side to side of pistons in the cylinder?
B bretto Seaman Joined Sep 20, 2006 Messages 59 Sep 23, 2006 #1 Is it normal to have a little play side to side of pistons in the cylinder?
baxtr Petty Officer 1st Class Joined Jul 16, 2006 Messages 387 Sep 24, 2006 #2 Re: Piston slop the pistons will slop slightly, the piston rings take up the rest. If your rings are also sloppy, you will lose compression.
