  #1
Old November 29th, 2006, 12:41 PM
v12mac v12mac is offline
Default Yamaha pre-mix confusion 2 cylinder engines 50-1 or 100-1
What is the correct ratio for a C 55 hp 2stroke 2 cylinder? (This motor did not come with oil injection) I have been running 50-1 with no problems, but some folks are telling me that the 2 cyl motors are set up to be pre-mixed at 100-1
Can any one shine some light on this? Are there 100-1 pre-mix motors out there?
Mac
  #2
Old November 29th, 2006, 02:05 PM
SCO SCO is offline
Default Re: Yamaha pre-mix confusion 2 cylinder engines 50-1 or 100-1
Hello Mac,
I'm going to add to the confusion. I have a 2005 50hp 3 cyl 2 stroke w oil injection. It doesnt use much oil. I am trying to calibrate it as we type. I marked the sight tube on the oil resevoir at full gas tank. It will take a while to run the gas through it but Ill measure the amount of oil to refil to my mark and the amount of gasoline to refill the tank. I have heard 100:1 for this engine but dont trust the oiler till I can see what it puts out. The manual does say that if the engine hasn't been run in a year, that you should start it with 50:1 mix. Their current models greater than 50 hp all have oilers. It doesnt specify an oil ratio for these on the yamaha website or in my manual. For the new current tiller models through 25hp, the website specifiys 100:1. This url should take you to the yamaha owners manual location.
http://www.yamaha-motor.com/outboard...d_manuals.aspx
I looked up a 2000 c50 and it takes 50:1. Let us know what you find
  #3
Old November 30th, 2006, 03:18 AM
deejaycee_2000's Avatar
deejaycee_2000 deejaycee_2000 is offline
50:1 ... 50:1 .... 50:1 ...... an engine with oil injection will mix the oil according to the rpm, at idle it would be about 100:1 or about 125:1 and at pullaway maybe 30:1 or 50:1 depending on the work load ..... if you stop and pullaway and stop and pullaway it will use much more oil than just cruising without stopping, check your oil level after skiing for the day, you will see the difference ....... it is better to just run your 2-stroke on 50:1 even if the manual says 100:1 it won't hurt the motor ....... I have a 15hp yamaha that is supposedly 100:1, but I run it on 50:1 to be safe, never had a problem ......
__________________
__________________________
... THE MAXIMUM HORSEPOWER IS NEVER ENOUGH ...
  #4
Old November 30th, 2006, 12:08 PM
I'll stick with 50-1 on this motor.
Deejaycee, in keeping with your motto "The maximum hp is never enugh" We set up this 13' whaler with a C55hp Yammie.
I wonder if it will float a 90hp??.....
Mac
P.S. I don't want to start a whole Hp thing, this boat is never used and nobody will ever ride in it.
  #5
Old December 1st, 2006, 02:47 AM
hehehehehe ..... yeah that can be dangerous, some people on this forum get worked up very quick when it comes to going over the max hp, but everyone is entitled to their own opinion, here in SA we just do whatever we want so it doesn't matter to me ...... I am sure that whaler would fly with that 55 yummy, although that is a 2-cyl right? it is pretty light compared to a 90hp so the whaler woul be cool with the 55, with the 90hp, I would not attempt that myself hahaha, the 90hp is very heavy so I would say no it probably would not float, but you would never know unless you try it , try everything at least once I always say hehehe
__________________
  #6
Old December 1st, 2006, 09:59 PM
rodbolt rodbolt is offline
actually the 13 whaler is scary with a 90 yamaha.
the 70 is all I wish.
we do have nuts here as well .
on the fuel mix, most smaller yamahas were technically desined to run at 100 to 1 but in practicile experience 50/1 works better in real life.
the precision blend oil injected yamahas will vary the amount of oil injected depending on throttle angle and engine RPM. the actual ratio is determined by the throttle angle and the speed of the pump(RPM)
  #7
Old December 11th, 2006, 04:15 PM
Deejaycee, yep it is the 2cyl. We got lucky and found it here locally in great shape, may have been a freshwater only motor. It runs great and is the fastest 13 I've ever run. I had a 7 1/2 hp on a 13 when I was a kid and I thought that was fast!
Wow, Rodbolt I was just dreaming but it seems like you have seen one with a 90hp!
Mac
  #8
Old December 12th, 2006, 11:51 PM
not that I reccomend it, but yes. I have an idiot friend that did it.
dunno who was the biggest idiot.
him for doing it or me for actually riding in it, once.
however your also chatting with an idiot that put a 150 yamaha on a 15' monark mcfast. .
above 60 the steeering locks .
dont ask dont tell.
one day I looked up, had a motor, had a hull, had a few beers and the rest was history.
  #9
Old December 13th, 2006, 02:46 AM
too be honest .... not even me will attempt that with a 90hp standard engine .... if it is a light motor like my 50hp engines that is boosted to 90hp (yet to be proven by me soon) maybe then .... hey rodbolt you should have a ride with me on my racing inflatable ... afterwards we drink ... hahaha .... also testing my 16.5 foot raven with a 200hp yummie soon .... should be fun .... I am crazy, maybe, but not an idiot ... safety first (not) ..... anyway, those 2 cyl 55hp yummies are "never say die" motors, as a kid I drove the hell out of one I have, still runs perfect today with no problems .....
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
What are the differences in Yamaha 225 and 250 4 stroke engines John Toutkoushian Non-Repair Outboard Discussions 3 December 14th, 2006 10:58 PM
CONFUSION on Merc / Yamaha models to choose (again same boring question) Nucleus Non-Repair Outboard Discussions 21 March 23rd, 2006 03:02 PM
Are there any good 4 cylinder I/O engines? supercab78 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 36 August 11th, 2005 08:50 PM
Forum confusion? Yamaha 5HP post RegH Yamaha & Suzuki Outboards 3 April 26th, 2003 05:12 AM
Yamaha outboard 4-stroke Engines ERR446 Yamaha & Suzuki Outboards 8 January 28th, 2002 05:14 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
