Re: Choosing an air compressor...
The best way to decide what you need is to look at what you're planning on running. On your list, either the buffer or drill will consume the most air. Assuming you want a "hobbyist" unit and not a 240v commercial unit, there are many that will do the job. Forget about PSI. What you're looking for is CFM. Compressors will be rated at blankCFM at 45psi and blank psi at 90psi. More is better. Make sure the CFM rating for the compressor you choose matches what the tools you plan on using need. If you're going to paint with it, get a decent size tank ( 20-30gal) as smaller tanks get warmer air more often and thus more moisture. Also, don't forget about gas engine compressors. They are comparably priced to 120v electrics but their output (CFM) is far greater. I have three compressors, 1 pancake for nailguns, 1 30gal 120v. for painting/impact wrench, etc., and my Jeep that I outfitted with engine operated OBA (~16 CFM at 100psi!) Each is suited to its own purpose.
