  #1
Old November 26th, 2006, 04:45 PM
jjhdds jjhdds is offline
Default 77 115 v 4 evinrude ignition problems
My 77 rude has been acting odd lateley,the tack was all over the board now its stuck at 1000 rpm,my motor will start but WILL NOT TURN OFF,I also get my hot horn to go off when the motor is running, but the hot horn will not go ON when the motor is running in the OFF position,any thoughts.Thanks
  #2
Old November 26th, 2006, 05:19 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: 77 115 v 4 evinrude ignition problems
sounds like you have a short in the controller. if it is the original controller, and wiring harness, the insulation gets brittle and falls off. could be any where in the harness. could be broken kill switch wire (black/yellow ). the ignition is killing the accessories line but no the engine.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old November 26th, 2006, 06:31 PM
ezeke ezeke is offline
Check and clean the connections at the red plug at the engine. Check the harness just inside and outside of the engine housing for broken/shorted wiring.
Then use an ohm meter to check for continuity on the individual wires.
The black and yellow wire that runs from the ignition switch to the power pack works by shorting the power pack when the key is turned to "off".
The Grey wire that runs from the engine's terminal block to the control and then to the tachometer provides the pulse to activate the tachometer.
Since the two wires are basically unrelated, you may have just lost your ground at the engine, so check the wiring at the engine by removing, cleaning and reconnecting each wire.
  #4
Old November 26th, 2006, 08:22 PM
Forgot to mention that you might want to disconnect the battery while you do all of that checking.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Hey Joe, my 200 evinrude has ignition problems po-it Johnson & Evinrude Outboards 4 September 21st, 2004 04:23 PM
82 Evinrude 115 ignition problems?? gt1878 Johnson & Evinrude Outboards 0 June 1st, 2004 07:38 AM
Evinrude XP 150 Ignition Problems vaughan376 Non-Repair Outboard Discussions 1 January 25th, 2004 07:29 AM
IGNITION PROBLEMS ON A '69 EVINRUDE ranger_racerxlt Johnson & Evinrude Outboards 6 September 1st, 2003 06:36 PM
Evinrude 9.9 ignition problems Vahevala Johnson & Evinrude Outboards 1 April 5th, 2003 04:53 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
