I finnally got the new coil on the ol' girl and she started right up, running on both cylinders. I idled down low and smooth, but I couldn't stop there. I thought I would tinker with the idle mixture. I "assume" its the screw that is to the right of the carb opening that's recessed in a cylintrical hole. If so, when I turn it counterclockwise the I dle goes up past the rpm I think it sould be. I just want to be sure that is the mixture screw. If it is I will need to find a way to set the idle down when I get the adjustment right. I have never run this motor, I bought three of these motors and built on good one from parts. I may not have gotten the throttle contol lever in just right or something. I am a 25 yr auto tech but a novice outboad mechanic to say the least. Any input would be great. Thanks, Chris
