  #1
Old November 24th, 2006, 11:34 AM
JADED JADED is offline
Default WP Gauge to 70 yamaha
Where is the best place to 'T' in for a water pressure gauge on a 70 yam.?
  #2
Old November 24th, 2006, 11:42 AM
rodbolt rodbolt is offline
Default Re: WP Gauge to 70 yamaha
actually a WP guage is not reccomended on that motor.
its a low pressure high volume system and yamaha does not reccomend the use of a WP guage.
whats funny is that was actually a test question some years back.
I would prefer a temp guage over a water pressure anyway.
its just to easy to melt a motor down and still have water pressure.
thats what is so wonderful about audible alarms, you dont have to be watching them for the alarm to get your attention.
  #3
Old November 24th, 2006, 11:51 AM
Any one want to buy 2 water pressure gauges?
I'have jackplates fitted to twin 70's and I'm testing heights and props so I want to keep an eye on the pickups as they are standard.
What would you suggest?
  #4
Old November 24th, 2006, 04:34 PM
I would suggest a single 150, would go faster.
were it me and I was hell bent on a pressure guage I would drill and tap into the top of the block on the water passage from the exhaust plate to the block.
use whichever tap and tap drill size to fit the threaded fitting.
not saying it cannot be done there are just to figgues on what water pressure will be.
I cant remember if the 70 block has the 10mm threaded port but I dont think it does as it was never intended to have it.
if your 70 has a hose between the exhaust plate and tell tale restrictor you can tee it in there and run with the engines full down to get a base line pressure.
  #5
Old November 25th, 2006, 07:59 PM
I havn't seen a port as I have been looking, there is a bolt on the block side of the thermostat that looks like it cold be a port though.
I was going to t in to the tell tale but thought that taking the pressure at the open end of a hose wouldn't be the best. I have never taken off a lower unit, is there any where just after the water pump?
If I drill and tap the block would I need to take off the exhaust cover to see where the water passage runs? Is the gasket re-usable? Sorry about all the questions.
I get you about the temperature gauge but will a pressure gauge give a quicker indication if I am running to high. The gauge i am looking to use is 0-20psi
Twin or single is another issue as I do alot of offshore fishing. Just looking to maximise rig I have.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Yamaha rpm gauge CaptainRick Non-Repair Outboard Discussions 2 July 9th, 2006 09:40 AM
Yamaha Gas gauge problem snookie Electrics, Electronics and Trolling Motors 2 April 1st, 2005 10:37 PM
Yamaha gauge help. bernieb Non-Repair Outboard Discussions 1 November 2nd, 2004 02:34 PM
Yamaha gas gauge wiring help Gep Yamaha & Suzuki Outboards 8 July 17th, 2004 02:24 PM
yamaha multirunction gauge reel retirement Yamaha & Suzuki Outboards 1 August 21st, 2003 04:20 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
