blubayliner
- Sep 15, 2006
- 22
During my last outing I was running at cruise with some friends, all was well so I put a few more RPM's to her (1976 Bayliner 302/ 888 outdrive) and lost forward thrust, except at idle. I was loosing the Gimbal bearing too, so we got towed in and hauled it home. I didn't check reverse (it just occured to me now that I should have tried that). I ran it on the hose at home to rinse out the salt. There is no or little noise, outdrive oil appeared fine (some fine metal shaving on the vent magnet). I can put it in gear and the prop won't turn against the engine.
I removed the outdrive today... gimball is bad.. water got in there from somewhere (it's a new bellows); u-joint seems fine..
Q. Could the drive assembly allow slippage?
Q. Is there some linkage on the engine side of this that could be a problem?
Q. How can I troubleshoot if it is fwd or rvs gears?
Can I close my eyes and have it go away?
Thanks for reading my post.. I would appreciate all comments!
