imported_frenchy2
- Sep 15, 2006
- 7
I have read all the forums and need more help please. My DT55 runs great in the driveway with a hose hooked up but when i put it in the water(under load) it refuses to idle and keeps dying when i shift from neutral to forward and reverse.
I had the carbs cleaned by a boat yard and i have new fuel pump.
The engine runs great above 1500 rpm. Checked all fuel lines etc.
Could it be the TPS. I and the teck are at a lost.
Also when i adjust the idle screw i can keep it running above 1200 rpm but if i throttle back below 1100 it seems to not run on all 3 cylinders and dies.
I DO NOT KNOW IF THIS IS RELEVANT BUT WHEN I RUN THE BOAT FOR MORE THAN AN HOUR, THE WATER COMING FROM THE HOLE AT THE SIDE OF THE ENGINE SEEMS TO ALMOST STOP.
Thank you and i hope someone can help
