  #1
Old November 16th, 2006, 08:35 PM
cwmalloy cwmalloy is offline
Default 1999 Evinrude 175 HP Ficht
- 1999 Evinrude 175 HP Ficht (02:23:08 12 Nov 2006)
PM OptionsForwardReply in New PMReport To AdminDelete PM ThreadEdit PMMove to: Inbox
I just bought a 1999 Stratos fish and ski with a 1999 175 hp Ficht Evinrude. Boat and motor are in like new condition. I didn't know anything about the history of Fichts until I bought this boat and started reading up on the engines.
From what I have read, I believe the key to protecting the motor is not to run at slow speeds under a load as this builds extra soot that will absorb the oil and rob the lubrication. Also, use Evinrude RAM oil.
I had the motor decarbonized and the plugs changed and indexed.
I plan to install a hydro-fin stablizer to help with the hole shot and reduce slow speed operation under load.
I have three questions:
1) will running extra oil mixed in the gasoline help lubrication or increase soot production?
2) will running at idle speeds (like trolling) be bad for these Ficht engines, or is the extra soot production only under load?
3) does anyone have any other suggestions on how to take care of Ficht engines to get a long life out of them?
  #2
Old November 16th, 2006, 08:40 PM
Fl_Richard Fl_Richard is offline
Master Chief Petty Officer
Default Re: 1999 Evinrude 175 HP Ficht
Absolutely not an expert her but I've heard without all the updates and service modifications they can be problematic.
More expert opinions to follow below
  #3
Old November 17th, 2006, 02:46 AM
JUSTINTIME's Avatar
JUSTINTIME JUSTINTIME is offline
u can not run pre-mix in injected motors
are u doing this?
__________________
HUMAN BUILT = HUMAN FIXED
CERTIFIED MARINE TECH
  #4
Old November 17th, 2006, 06:41 AM
emdsapmgr emdsapmgr is offline
I would inquire with the Bombardier Customer Service hotline. Ask for someone in Tech Service to help you. Ask if there have been any service mods completed on the engine. Have your serial number handy. One of the last ones issued by OMC prior to bankruptcy was a major mod. Included a software update, a new fuel pump, some brackets for the injectors and a couple of other items. The mod (parts only) is rather expensive (perhaps in the $500 range), but is should be available and should be done on the engine. If your engine is up to date on mods, there should be no restrictions on running the engine. Run the Bombardier XD50 oil in the engine.
  #5
Old November 18th, 2006, 10:14 PM
Quote:
are u doing this?
I am not pre-mixing, just wondered if a little extra oil in the form of pre-mix would be a good idea?
THANKS BILL
  #6
Old November 18th, 2006, 10:18 PM
Quote:
THANKS! I will definitely follow your advice and try to get in touch with the tech service group at Bombardier. (I assume that I can get their numbers by searching the internet). Is the XD50 oil a low soot oil? Is it the same thing as the Evinrude RAM oil?
The engine would definitely be worth $500 in up to date modifications, if that means good long service.
THANKS AGAIN
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1999, 175 Evinrude Ficht, anything I need to know? loctopus Johnson & Evinrude Outboards 3 September 5th, 2007 07:19 AM
1999 ficht evinrude gwu03 Johnson & Evinrude Outboards 4 September 4th, 2007 10:38 PM
1999 Evinrude 150 Ficht imported_BigRon Johnson & Evinrude Outboards 1 August 8th, 2006 06:30 AM
1999 evinrude ficht mattttt25 Johnson & Evinrude Outboards 5 March 31st, 2005 05:17 PM
1999 Evinrude Ficht 150 gkpc Johnson & Evinrude Outboards 4 July 9th, 2002 09:08 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
