  #1
Old November 14th, 2006, 01:16 PM
tsgarbi tsgarbi is offline
Default Power Pack on Mercury 150
1996 Mercury 150 black max
Serial # 0G181260
Model # 1150413RD
At cruising speed:
Can the power pack abruptly kill the engine and immediatly start back up? Run for a while and abruptly stop again?
Help!
  #2
Old November 14th, 2006, 01:26 PM
Laddies Laddies is offline
Default Re: Power Pack on Mercury 150
Probably not inless it's a bad bias in 1 of the switch boxes, that will almost have to be tested with a DVA to find the trouble, you might try to remove the kill wire (blk/yellow) from the boxes first and running it to see if the problem is in the kill circurt
Mercury has switch boxes and early Rudes had power packsd
__________________
PLEASE, no service questions in PMs thats what the forums are for.
  #3
Old November 14th, 2006, 02:32 PM
gss036 gss036 is offline
Check for corrision inside the large bayonet type fitting where the wiring harness connects to the engine. It is tucked in a recess on the lower starboard side of the engine. Just pull it apart and clean it up and spray w/some type anticorrision spray. I had mine arc across and burn the connections. It is just something that you never think of doing on normal maintence.
  #4
Old November 14th, 2006, 06:00 PM
Thank you,
I looked all over for a black/yellow but I cannot find it. Can you tell me where it is?
Thank you
  #5
Old November 14th, 2006, 06:01 PM
Quote:
Thank you, I will try and let you know.
  #6
Old November 14th, 2006, 06:19 PM
Quote:
The connections looked really clean with no corrosion but
Removed the fitting, cleaned it and sprayed anti corrosion spray and re connected. Thank you, Every little thing helps.
  #7
Old November 14th, 2006, 06:27 PM
There on the end of the boxes that have 4 terminals second wire from the end you will have to see which end and be sure to remove them from both boxes
__________________
  #8
Old November 14th, 2006, 06:38 PM
Found them, black with yellow stripe.
Do I just remove them both? tape the ends and that's it?
  #9
Old November 14th, 2006, 07:13 PM
Yes, you don't even have to tape them as they are ground off wires, if you ever find one with voltage on it, it will fry the boxes
__________________
  #10
Old November 15th, 2006, 01:24 PM
Thank you very much
I will take the boat out this weekend and give you an update
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Evinrude 115 Power Pack Not Getting Power monkeybidz Johnson & Evinrude Outboards 2 March 29th, 2007 11:19 AM
Half of my power pack doesn't work. Is this only the pack?? Jquest Johnson & Evinrude Outboards 10 August 12th, 2004 03:51 PM
power pack ? Kesh Johnson & Evinrude Outboards 27 May 13th, 2003 05:46 PM
mercury 9.8 power pack Allen Henry Mercury & Mariner Outboards 4 July 24th, 2002 07:23 PM
What exactly is a power pack? epresutti Johnson & Evinrude Outboards 2 July 18th, 2002 02:16 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
