  #1
Old November 13th, 2006, 12:33 AM
casi77 casi77 is offline
Default 80s mariner 25hp - to remove carrier bearing? swap mariner -> mercury casing
its a 80s mariner 25hp, i searched the forums but couldnt find anything on how to remove that big screw in type carrier bearing. searched the web also on special tools but the ones i saw in the pictures doesnt seem like it would open that. i have the original lower unit and another one of a mercury, original one was damaged (hit a rock) i had to really cut the casing off with a angle grinder (cutting bit) then with a flat head screw driver and hammer was able to remove the carrier bearing and all the gears etc. in it. Purpose was to swap the original drive shaft and shift shaft to the mercury casing. Now I dont want to do any damage to the mercury casing, so looking for that tool!! Help please..
its part#53 in: http://www.dougrussell.com/partscata...3,10,12,17 ,4
  #2
Old November 14th, 2006, 01:59 PM
Default Re: 80s mariner 25hp - to remove carrier bearing? swap mariner -> mercury ca
nobody knows which tool i should use to open up that bearing carrier on a mariner 25hp ?!
  #3
Old November 17th, 2006, 02:16 PM
TriadSteeler TriadSteeler is offline
I think that tool has been discontinued by mercury. However, there are a few aftermarket versions. They are around $75.00
Don't even try a screwdriver. Depending on how long the spanner nut has been on there, it will probably require heating the casing outside the nut to loosen it.
I would suggest taking it to your local marine shop and have them loosen it for you. It would probably be cheaper in the long run. I say this because after you loosen the nut, you are going to need the special slide hammer attachment to pull the bearing carrier, thrust washer, and reverse gear off of the prop shaft. That thing is about $250.00. If it is not too tight, a typical slide hammer with reversable hooks will work, but you would be better off taking it in to the shop because they can loosen the nut and pull the bearings and gear off of the shaft in about 15 minutes. Unless you are having them overhaul the LU, most shops will do this for far less than the cost of the tools. Also, if you are removing the shift shaft, there is a special tool requred to remove the shift shaft bushing. $13.00
BTW, I have also seen that spanner nut tool on ebay for around $30.00.
  #4
Old November 17th, 2006, 09:28 PM
the mariner 25hp lower unit that i broke open, does not need any sort of puller, the carrier itself is just a screw in type, not like the ones you see in the 65hp or 40hp models..
Also the shift shaft is not the same type as like other ones, it does not have a shift shaft busing where you require a special tool. I know which tool you are talking about.. length of the shift shaft on the 25hp is roughtly the same as the drive shaft, if you pull on it, it comes out of the casing.
i couldnt find that particular tool to remove this carrier on the internet, maybe im not looking right at the pictures.. if its not to expensive i like to buy.. if not, im going to have to bring it in to a marine shop to have them open it.
but there must be a tool to open that!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mariner 60 - Lower casing removal Dave Walton Mercury & Mariner Outboards 1 August 21st, 2005 02:36 PM
Mariner 75 Broken Bearing Carrier Trailgoat Mercury & Mariner Outboards 3 March 19th, 2005 04:12 PM
How too remove busted bearing carrier 20hp merc breedy Mercury & Mariner Outboards 3 January 10th, 2005 09:27 PM
remove oiler from mariner ??? basszzilla Mercury & Mariner Outboards 2 October 5th, 2003 05:22 AM
how to remove the oil injection on a 90hp mariner? lake_time_2 Mercury & Mariner Outboards 2 December 15th, 2002 04:25 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
